Help (Solar Charge Controller)
Discussion in 'General Electronics Discussion' started by Rogueraven, May 28, 2013.
  1. Rogueraven
    Rogueraven
    8
    May 18, 2013
    (No Solar Grill this time so put the mutton away)
    I want help picking a Solar Charge controller, I've looked about but seems there are a lot of these things on the market, This is for my solar lamp circuit (Panel charge battery light lamps) I have been reading a lot so now hopefully I will be building this the correct way.
    Also I do not know much about 12v car or leisure batteries would this sort of project require a 12v deep cycle battery or a short cycle ? seems what I've been reading fail to be specific
  2. (*steve*)
    25,496
    2,837
  3. Rogueraven
    Rogueraven
    8
    May 18, 2013
  4. (*steve*)
    25,496
    2,837
    Well, it's hard to tell if it's appropriate without knowing details of your setup, and I have no idea of the reliability of that unit.
    However, if you've followed the rules of thumb I suggested in that other thread to appropriately size your system, and the maximum current that this device will be subject to is in the range of 50% to 75% of it's rated maximum (lower is better) then it may well be suitable.
