Help rf linear amplifier 11Mhz
Discussion in 'Radio and Wireless' started by Boris20, Dec 2, 2014.
  1. Boris20
    Boris20
    Dec 2, 2014
    I need an expert advice - I have an output from arbitrary waveform generator: sinus signal at 11Mhz, max amplitude 5-10V, low current (about 100mA). Is there a rf amplifier module that I could connect to this output through SMA to have a stronger signal (10 times at least).
    I would appreciate a lot if someone could help!
    Boris
  2. hevans1944
    hevans1944 Hop - AC8NS
    4,460
    2,075
    Jun 21, 2012
    Minicircuits.com has a variety of linear amplifiers you should investigate. Their ZHL-5W-1 seems appropriate for your requirements. See attached PDF file.
