Help replacing surface mount capacitors
Discussion in 'Electronic Repair' started by Tom, Jan 19, 2004.
  1. Tom
    Tom Guest
    How do you read surface mount electrolytic capacitors, they have these
    numbers on the top:
    220
    CHA
    7C7 (big ones)
    47
    165
    7Q7 (medium)
    2.2
    HHA
    7K1 (tiny)
    Does anyone know what these mean?
    Also I am having trouble unsoldering them, they seem almost 'welded' to
    the circuit board.
    Can I pull/cut them off somehow and solder new ones in their place? Is
    there any way to test them while they are still on the circuit board? I
    have a meter but it is designed for the capacitors (with long legs) to
    be pushed into it, If I made some leads would it be possible to measure
    them on the board with this?
    Thanks, Tom
  2. Guest
    You could make leads and test them. I've personally never encountered
    a bad surface mount cap. The cap could be glued down ( a hint for
    reinstalling them, btw)
    -Chris
