D
Dave, I can't do that
Hi people,
OK, out of my depth here so be gentle.
I have a 6" x 4" PCB with a display and other stuff on it and it is
supposed also output a variable PWM signal of 5vdc at 5KHz. Tracing
back from the output connector, the first chip is a SN74LS123N,
Monostable Multivibrator.
It is putting out a square wave but at only around 460mv, it
fluctuates between 440mv and 480mv.
Using a Tektronix TDS-210 scope, I am getting a wildly drifting
frequency ranging from about 3.8KHz to a little over 8KHz.
Would this indicate the chip is faulty and that by replacing it I can
solve this problem?
OR
Could it be something before that chip?
The chip has 5 caps in it's vicinity and 2 resistors, I am guessing
that some or all set the 5KHz frequency. Not all of those may be
connected to the chip but they are close by. It is difficult to follow
the traces as it is a multi layer board. One of the small blue caps
with 473M as the only marking looks like it has been replaced as there
is resin marks around the soldering.
I know it is probably a question like, "how long is a piece of string,
" But I am totally dumb when it comes to digital stuff but quite
capable of swapping out the chip. I live out in the boonies and it
takes about a week for stuff to get here so if I have to order I'd
like to get the right thing.
Thanks for any crumbs you guys can sprinkle.
solve this problem?
OR
