A
[email protected]
I really need your help. I embarked on assembling one of the circuits posted on the page, specifically the Game Show Who’s First Circuit. I purchased the parts and put it together to what I understand is correct. Here is what I’m seeing.
With a setup of a total of 6 stations, but with only 2 connected for test.
1.The relay clicks to trigger the buzzer.
2.When a button is pushed, it turns on it’s corresponding light.
Problem: When button is pushed a 2nd can also power it’s light. Essentially it isn’t locking out the other stations.
I tried checking if maybe the button pushes were too close together it might light both, but with time in between pushes the test setup lights either way.
Does it need the minimum 3 stations in order to work properly? I suspect that it shouldn’t matter how many stations are wired it should still lock them out. If you could please give me some guidance it would be greatly appreciated. I’m kind of stuck and not sure where to proceed.
Regards
Ariel
Regards
Ariel
