Help! plz making an amplifier board
Discussion in 'Troubleshooting and Repair' started by akhb76, Jul 11, 2016.
  1. akhb76
    akhb76
    Jul 11, 2016
    HI
    I`m so noob in electronic
    I assembled an Amplifier board and when testing it in low volume everything is fine but when increase volume the sound became corrupted and nothing can be heard from song. when I touch ICs one of them is hot and the other one is cold.
    my power supply is 12v 4Amp and its sure enough also my speaker is strong enough and the problem is surely somewhere in the board.
    I attached some photos from board.
    Note: the missing capacitor is coonected from under board.
    sry for my bad english
  2. davenn
    davenn Moderator
    13,619
    1,882
    hi
    welcome
    you haven't told us quite enough
    what are the IC's show us a schematic of the circuit
    show a photo oc the underside of the board
  3. hevans1944
    hevans1944 Hop - AC8NS
    4,521
    2,104
    Jun 21, 2012
    Well, here's a schematic from the vendor's website:
    [​IMG]
    There should be two of these circuits on the circuit board since this is supposed to be a 50 watt stereo amplifier. My guess (since one of the ICs runs hot) is a shorted electrolytic capacitor, perhaps C9 or C12. Since it's a kit, check to make sure the electrolytic caps are not installed wth the wrong polarity. According to the Google Translate description this is an H-Bridge amplifier, but I don't read Farsi. Here is a better picture of the stereo amplifier, also from the vendor website:
    [​IMG]
    akhb76 likes this.
  4. akhb76
    akhb76
    Jul 11, 2016
    wow
  5. 73's de Edd
    73's de Edd
    2,900
    1,232
    Aug 21, 2015
    You forgot to install capacitor C9 on the board.
    You will get no audio, until you install that electrolytic capacitor .
    Just now read back and caught the bottom install. . .assuming that it's polarity is correct ?
    You have symmetrical use of two amps here.
    Take a meter and place it in it's DC voltage position and test the like voltages between like pins of each I.c.
    Since each voltage would almost be the same, expect very little voltage difference.
    If you experience a significant voltage difference, explore that situation.
    SETS of pins to be tested between would be:
    8-6-7-5-12-1 and 4. the others are being shared connections.
    73's de Edd
  6. davenn
    davenn Moderator
    13,619
    1,882
    I think you meant C10 ;)
    sorry, you were referring to his original pix
    which of course the speaker is disconnected :)
