help please
Discussion in 'General Electronics Discussion' started by ian707, Feb 1, 2013.
  1. ian707
    ian707
    4
    Feb 1, 2013
    what i wanna do is like making it to on/off
    if you put coin the pc will automatically power on then when time ends its like you are pressing the power button to shut it off thank you very much...:D
    [​IMG]
  2. Miguel Lopez
    Miguel Lopez
    252
    63
    Jan 25, 2012
    LED and phototransistor (or integrated optocoupler) sensing the coin in two places.
  3. ian707
    ian707
    4
    Feb 1, 2013
    what will i do sir...sorry for being so noob sir Lopes.
    thank you very much for replying.
    when i'm connecting the relay to motherboard of pc...it will turn on then shutdown after 3sec...what i wanna do is when time goes zero it will shutdown..
  4. davenn
    davenn Moderator
    13,833
    1,950
    You are showing several circuit boards in your first post
    but we have no idea what those boards do
    you need to do some explaining ... links to info on those boards, circuit diagrams etc
    but basically you need
    1) a coin detector
    2) that will operate a timer circuit, that when it counts down the required time it will
    3) activate the PC power switch circuit
  5. ian707
    ian707
    4
    Feb 1, 2013
    sir i have a coin detector..i think the relay is my problem it is always alive i'm a total noob wew... :(
    [​IMG]
    what i wanna to happen is like i'm pressing the power botton when times start time end ^_^
    [​IMG]
  6. ian707
    ian707
    4
    Feb 1, 2013
    help
    help help help ^_^
  7. Miguel Lopez
    Miguel Lopez
    252
    63
    Jan 25, 2012
    If you already have a coin detector, then the question is:
    What kind of signal that coin detector gives when it detects the coin? Can you tell us that?
    Using that signal (i.e: a digital level change) you could trigger a monostable (i.e: 555, 4047) and this monostable could power the relay for the desired time.
