Help please identifying another part - This one from an NEC TV.
Discussion in 'Electronic Repair' started by Randel Chiffiald, Apr 24, 2007.
  1. I need to replace a 2.2 mfd 160 V cap, but I don't know which type
    of capacitor,(electrolytic, tant, mica, poly... etc.) it is, and I haven't
    opened the set yet because although it has a problem, it is still watchable
    and I'd like to find out the type of cap so I can buy it before hand and
    swap it at the same time I first open it up for service as not to
    inconvenience the customer, (who happens to be my ex, and you KNOW how
    touchy that situation can be right? She's my ex for a very good reason
    <vbg>) And obviously, seeing as who it is, you know it's going to be a
    "government job" Know what I mean?
    SO, if anyone maybe has the parts list, schematic, anything that
    will tell what kind of cap it is, I'd REALLY appreciate it if you would let
    me know
    BRAND : NEC
    MODEL OR CHASSIS : CT-2505A
    PART NEEDED : C414. 2.2 MFD @160 VOLTS.
    Thanks a lot everyone.
    Randy
  2. Guest
    Guest Guest
    If your whore wants to look at shit on TV, then you should accommodate her
    the easy way. Instead of jacking off TV gadgets, just gouge her eyes out
    with a spoon, and jam them up her ass with a ball pein hammer!
  3. Chuck
    Chuck Guest
    It's a polarized 105 C electrolytic capacitor.
  4. HOw in the world can you know that it's a specific capacitor without
    having opened the tv set?
    Either you're guessing at what it might be, or you've done the old
    "I took it to a repairman, but they wanted $200 to repair it, so I'm
    going to do it myself. But I need to know, what's a capacitor?".
    Anyone who really had an idea would be able to make a very good guess
    on what type of capacitor.
    Michael
  5. John Fields
    John Fields Guest
  6. Simple, it's a common, well documented malady with this particular
    model. The set displays the exact same condition described by the numerous
    sources of common technical problems with certain TV models. In the
    description of the capacitor however, the various sources of this
    information fail to provide specific information about exactly what type the
    capacitor is. An educated guess would be that it is canned electrolytic, but
    there is also the possibility that they have used a tantalum cap in this
    circuit. It would make a difference.
    You couldn't be further from the truth. I am a disabled, (and
    obviously semi-retired because of it) former R&D engineering tech and I also
    had a repair business myself. Because of the limitations posed by my
    disability, I had to quit and only work on personal and "friends" equipment.
    Most of my test equipment and documentation was either stolen, given away,
    or lost since then.
    You're absolutely right Michael, but as I explained above, a guess
    isn't always right, and I was hoping someone would have the information that
    would cinch it so I could do the repair in one visit. I have a difficult
    time getting around, and wouldn't be doing this repair at all if it weren't
    for the fact that my daughter lives with her mother and asked me if I would
    do this repair for her. I figure I'd at least try to do this while I still
    can. BTW, the RCA transistor I requested info on in another post is for my
    own set.
  7. What are you, some kind of troll? Of course I could buy a manual,
    but I asked for help from someone who might have one already, and would be
    courteous enough to share the information I needed with me. Most of the
    questions in these groups could be answered with "search for a manual for
    sale." That info is assumed, but not what was requested.
  8. Thanks you very much! That's a big help.
    Randy
  9. Very likely electrolytic. Could be poly. Sure isn't tantalum or mica.
  10. No, john is a regular on and
    most of the newsgroups.
    alt.binaries.schematics.electronic was created to exchange schematics
    and design ideas, not trade in copyrighted materials. John gave you the
    standard advice, for when someone requests something that isn't in the
    public domain.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  11. SuperM
    SuperM Guest
    Top posting TOFU Usenet retard!
    It is peen, btw, idiot.
    http://en.wikipedia.org/wiki/Ball_peen_hammer
  12. SuperM
    SuperM Guest
    Lemmie guess... you are too stupid to look at the designations you
    gave and tell what part it is?
    If that is the case, and it obviously is, then you are also too
    stupid to be working on it and particularly so without a manual, which
    any real technician would have, and want, and acquire before delving
    into such a repair.
    What makes you think that replacing that part is going to solve the
    root cause of what made it fail?
    If you are so dumb that you think you don't need a manual, what
    makes you think you have properly diagnosed the failure mode?
    Also, that part is identifiable from up to 26,400 miles away by any
    competent person, so if you are having issues doing so, you should
    most likely be the last idiot working on the chassis of a TV.
  13. SuperM
    SuperM Guest
    All three can actually reach that value, but *we* know for sure that
    it is an EL.
    The problem at this point is his attitude, and the fact that he
    couldn't ID it from a glance tells us he shouldn't be doing the repair
    *attempt*.
    He'll likely screw it up, or not repair the root cause for that
    part's failure, and end up having to get it professionally repaired,
    and after telling that guy what he already did, it will likely cost
    him twice as much to do it, as the tech will see the opportunity for
    the "idiot with a screwdriver" penalty imposition.
    Bwuahahahaha!
  14. You people really crack me up - really. If you could read beyond
    your own little contribution to idiocy, you would know how ridiculous you
    really sound. But then I wouldn't have such a grand time reading the tripe
    from people who think they know what they are talking about, and have all
    the answers, but couldn't be more wrong if they tried. Besides, the only way
    people like you talk the way you do, is that you hide behind a keyboard. If
    you were standing in front of me, the self importance you project when you
    feel safe behind your anonymity would disappear, and you might just become a
    human being. Should you have actually known me during the last 40 years I
    have been working in electronics, you would know that what you said is
    completely opposite to reality. I actually almost wish you would meet me in
    person after writing you thoughtless negative generalizations about me. If
    you did, and unless you have not a single ounce of shame, I have little
    doubt that not only would you feel about 1 inch tall, but seeing me in my
    current health, you would insist on doing the work for me. Time, living my
    life to its fullest when I wasn't holed up working on this or that project,
    and some poor personal choices have left me crippled, in a 24/7 hell of
    agonizing pain, and dependant on pure oxygen to survive. My will to live, a
    life long love and fascination for electronics, and first and foremost, my
    daughter, are the only things keeping me going. With this message, I simply
    asked for help with confirmation of the identity of a capacitor, nothing
    else, but some people are so filled with hatred that they have to heap it on
    anyone who happens to catch their attention. Yes, you people crack me up,
    but I feel sad for you. Even in my condition, I am a lot happier with life
    than you seem to be. Unlike some, I haven't given up yet. If I had, I'd have
    gone a long time ago. So thanks for the therapeutic laughter. If you feel
    the need to hide behind your shield and spew more vitriolic banter, by all
    means, go ahead. You'll have to forgive me if I do not respond. I much
    better ways to spend what time I have left. With luck, you'll keep me in
    stitches for a long time to come. Thanks to Chuck <> I have the
    simple information I needed, (thanks again Chuck!) so I no longer need to
    monitor this thread. For that, I owe Chuck big time! <LMAO> Ah, that's the
    ticket!
    Randy
    P.S. I trust that anyone else with similar problems as SuperM, and feels the
    same need to lash out at people, consider the above applies to you as well.
    This will save me from having to repeat myself and you can also consider
    this my final posting on the matter.
    Again,
    Randy.
  15. Guest
    Guest Guest
  16. Eeyore
    Eeyore Guest
  17. Chuck Harris
    Chuck Harris Guest
    Before you call someone an idiot, it is probably best
    to remember the words:
    "It is better to remain silent and be thought a fool than it
    is to speak and remove all doubt."
    Hammers are very old, and as such they have names that have
    gone through many variations as the tides of fashion changed.
    One of the early English names for any hammer with one curved face
    and one flat face is a "pane hammer"... pronounced "peen hammer".
    The hammer with a ball end, and a flat end has been known
    variously as a "ball pane hammer", a "ball pein hammer", and
    a "ball peen hammer".
    All are currently correct, and all are in any reasonable English
    language dictionary.
    -Chuck
  18. ehsjr
    ehsjr Guest
    John is some kind of (where the phrase "some kind of"
    means "of the highest order") expert.
    You would be surprised at the number of people who
    don't know that.
    Might be a better policy to appreciate helpful responses,
    rather than condemn them.
    Ed
  19. John Fields
    John Fields Guest
  20. Eeyore
    Eeyore Guest
    Good Lord ! Your mean streak is really showing today Fields.
    Graham
