Help on Optocoupler Gate Drive
min
Sep 7, 2010
3
Sep 7, 2010
3
I need help on the Avago HCLP-316J optocoupler Gate Drive.
Connect my circuit based on the datasheet recommended application circuit. But i did not connect any IGBT in first and without the Ddesat (100ohm and diode) at the Ddesat pin.
I want to see the Vout (VGE) have a output signal of +15V and -5V which frequency follow my Vin+ frequency.
Now the problem is the Vout output signal is +15V to -5V, frequency following the Vin+ frequency but not the duty cycle. The high side duty cycle always remain at 500ns.
What's wrong at this circuit?
Please advise.
Thanks.
Militoy
Aug 24, 2010
180
Aug 24, 2010
180
I don't have direct experience with this driver chip - but a quick scan of the datasheet shows that there is some fairly sophisticated internal monitoring circuitry looking at the IGBT load for faults - and changing drive, based on results of that monitoring. It would be unreasonable to expect "normal" operation of the chip, with open-circuited outputs.
