Help on dc motor small garage
Discussion in 'Sensors and Actuators' started by Dmiller2400, Apr 4, 2014.
  1. Dmiller2400
    Dmiller2400
    Apr 4, 2014
    Hi, I'm creating a small 10 inch cardboard garage that will lift straight up. I realize that I need the connect the top of the garage to the dc motor with a small piece of wire or string, but I do not want the dc motor to keep reeling the garage up, I need it to stop at a certain point. I also need the dc motor to go in reverse and let down the garage to the ground at the rate of about 1 inch per sec. I am a bit confused as of the best way to stop the garage at a desired point, and letting it down. The garage can go straight up. Any help would be appreciated
  2. duke37
    duke37
    5,343
    753
    Jan 9, 2011
    1. Use a microswitch which is activated when the garage is at its top limit.
    Use another microswitch to be activated when the garage is down.
    2. Use a Hall effect device to sense the presence of a magnet which is fixed to the garage.
    I will have to think about a suitable circuit.
