help newbe with 8051 uC
Discussion in 'Electronic Design' started by [email protected], Jun 9, 2006.
  1. Guest
    Know any good compilers and a good book? I'ld like to learn to program
    8051s. I've gotten an 8051 eval board from PJRC, but I'm just a newbe.
    I've been doing C++ in MSVC for years and played with Basic Stamp
    modules, but now onto 8051's. I'm looking for a compiler and a good
    book. PJRC says to use SDCC, but a DOS window is kinda yukie. I've
    used MicroChips MPLAB IDE for their robotic controller built around an
    8520(?) but it doesn't target the 8253 in my eval board.
  2. Pooh Bear
    Pooh Bear Guest
    Yes but it'll be tricky to find a copy of PL/M 51 now. Intel's microcontroller
    handbook of 1983 ? was a good source of info for 805x family btw.
    Graham
  3. Luhan
    Luhan Guest
    Intel 8051, a blast from the past! These parts still have a following.
    You need to Google around a bit to see what people are using to
    program them lately.
    I used to program them, wrote my own assembler, designed my own
    programmer. When PICs came allong, I completely jumped ship. There
    are very few advantages to using the Intel parts these days. Since I
    have a lot of experience with both parts, I would highly recomend
    learning the PIC instead. Its a learning curve either way, neither is
    easier to learn, but the PIC runs circles around the 8051.
    Luhan
  4. Luhan
    Luhan Guest
    Ooops, should have included this link....
    http://members.cox.net/berniekm/
    Luhan
  5. Well, I don't use SDCC, but sounds like you're confusing the compiler
    with an IDE. Probably you can use SDCC with Ultraedit or Eclipse or
    whatever so you need not spend much time looking at the yucky window.
    The best compiler for the 8051 platform is Keil, but it's not cheap.
    You may be able to get a code-limited version that will help you get
    started (I got one bundled with some moderately expensive realtime
    emulator hardware).
    By 8520, I assume you mean PIC18F8520. The MPLAB IDE targets *all* the
    Microchip line, but I think you're talking about a special version of
    Hitech C which is limited to one particular chip for target for
    robotics hobbyists. The latter is a DOS-based C compiler that can be
    integrated fairly tightly (if you ignore stuff like -fakelocal) with
    the MPLAB IDE. You can always program any of Microchip's line in
    assembler using MPLAB, which is free.
    The number 8253 suggests an ancient NMOS programmable counter-timer
    chip, but I assume you're talking about an Atmel AT89S825, which is a
    quite a decent, if a bit slow, modern and economical 80C51 derivative.
    The 8051 is still a *very* popular microcontroller architecture, with
    dozens of manufacturers supplying parts from ones compatible with the
    original 8031/8051 to 100 MIPS single-cycle parts. New parts are being
    introduced continuously. You can find 8051 cores in SOC designs, with
    24 bit ADCs, with DACs and so on, more variety than any other micro.
    You can even get one rated to operate at 225°C (typical life of 1 year
    operating at 300°C).
    I suggest you check out 8052.com and download the Intel manual for the
    MCS-51, which has an extremely well-written description of how things
    work.
    Best regards,
    Spehro Pefhany
  6. Ian Bell
    Ian Bell Guest
    Don't listen to him. 8051s are REAL microcontrollers, not toys like the PIC.
    Ian
  7. Ian Bell
    Ian Bell Guest
    The most popular C compiler is probably the one by Keil (keil,com). I would
    suggest you go to 8052.com and sign up for the message board. There are
    several hundred of us 8052 developers there. Plenty of tutorial material
    there too.
    Ian
  8. Ian Bell
    Ian Bell Guest
    The 8051 'Bible' is still available from Intel's web site.
    Ian
  9. 300°C -> what kind of solder do I need for that...
  10. http://www.logwell.com/tech/servtips/solder.html
    They don't have much that is good for service at that temperature,
    though there's a few choice for +200°C operation.
    Maybe some brazing alloy such as: 40Ag 28Zn 30Cu 2Ni. Lead free. ;- )
    Best regards,
    Spehro Pefhany
  11. Pooh Bear
    Pooh Bear Guest
  12. mc
    mc Guest
  13. JeffM
    JeffM Guest
  14. Guest
    Ah, another poor musician who blames the instrument!
  15. Guest
    Whoa, what did I get into?!?! Thanks to everyone, let me digest these
    comments.
    Yes, the MPLAB PIC is a robotic controller. ( I help in a school
    robotics club, FIRST Robotics)
  16. Luhan
    Luhan Guest
  17. Luhan
    Luhan Guest
    Notice that this response appears to come from someone to young to work
    legally.
    To be fair, my experience with the Intel parts is quite out of date.
    Still it is worth doing some looking around at both what a micro can do
    and what kind of support exists for it. Then, of course, maybe you
    just like one better than the other.
    Look for advice here, but make up your own mind.
    Good luck,
    Luhan
  18. Rich Grise
    Rich Grise Guest
    I've used an 8035, which is an 8051 with no ROM; it needs an external
    program memory, where I used a 2716 or so; the timer was kind of a PITA
    but I dug in because it was essentially a PWM task (driving Futaba
    servos). Another time, I used an 8048 to operate a little 2K FIFO ram,
    back when FIFO chips were so expensive it was worth it to have a weenie
    like me slap together a uP-controlled FIFO.
    Then, I got a gig where I used the 68HC11. I fell in love. Naturally,
    that beautiful Motorola architecture seems to have gone the way of the
    passenger pigeon. Sigh.
    Thanks!
    Rich
  19. Rich Grise
    Rich Grise Guest
    sci.electronics.design. >:->
    Cheers!
    Rich
