Help needed
D3nch1829
Jun 30, 2022
Jun 30, 2022
Hello,
I am In need of help on my project...
I need to speak with someone via facetime that has good knowledge of stepping up a very low voltage on a circuit board.
If someone could please contact me would be great
Nanren888
Nov 8, 2015
622
Nov 8, 2015
622
Like 5 volts to 50volts? power?
Or a 5microVolt signal that you want to see at 1 volt?
AC or DC?
What are the constraints?
bertus
Nov 8, 2019
3,321
Nov 8, 2019
3,321
Hello,
What is the very low voltage?
Has the input voltage any power?
What would be the wanted voltage?
You will never get more power out as there goes in.
Bertus
D3nch1829
Jun 30, 2022
Jun 30, 2022
Hey guys,
Thanks for helping,
I have .4 volts as constant input voltage and would like to increase to 5 to 12v if possible.
Regards,
James
I am in DC, I have most electronic components with breadboard etc.. transformers, transistors...
John Canon
Jun 1, 2022
91
Jun 1, 2022
91
Simple ... just put a 4.6 volt to 11.6 volt battery in series with your input voltage. Bingo ... 5 volts to 12 volts DC!
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Is this 0.4V a 'supply' or a signal?
If it's a supply then forget it. If it's a signal then apply it to a non-inverting op-amp arrangement with the appropriate gain (x12.5 to x30 variable).
Harald Kapp
13,719
13,719
Look up "energy harvesting". There are chips and circuits specifically made to source energy from such low voltage (low power?) sources.
Be aware that the input current is proportionally higher than the output current since energy must be conserved.
Example:
  • Output 5 V / 100 mA = 500 mW
  • Input 0.4 V / 1.25 A = 500 mW --- accounting for a non-ideal converter circuit input current will more on the 1.5 A side ...
