enoughwealth
- Feb 4, 2010
- 6
- Joined
- Feb 4, 2010
- Messages
- 6
Hi, I'm new here and need to some help designing a simple circuit to build a Peltier (TEC) cooler add-on for my Meade DSI Pro II CCD camera,
I've ordered a cheap TEC (TEC1-12709) which is rated at max 100W, 12 V (DC?) and 1.3-1.5 Ohms. The current is varied to control the amount of dT between the hot and cold sides of the TEC), with a max of approx. 8 Amps. I don't expect to run the TEC at maximum, as I don't want to cool my CCD camera below the dew point.
I've bought a heatsink/fan unit to attach to the hot side of the TEC unit, which is rated at 0.04 Amps (+/- 10%) and 12 V DC, which I figure means the R is 300 Ohm?
I'd like to run the wires from the TEC and fan into a recycled PC tower box, where I will mount an on-off switch and TEC control (rheostat?), fuses etc. onto the back of one of the HDD slot panels. Power will either be supplied from the PC power supply (V?, Current?) or I'll install a power board inside the empty PC box and use a plug pack to power the TEC/fan circuit (eg. 12V 4500mA? - I have some old plug packs sitting around eg. 12V 500 mA, 15V 1500 mA etc. I'll buy a new plug pack if needed).
I figure I'll need to put the TEC and fan in parallel, and have a fuse for each (8A for the TEC and 0.045 A for the fan). The rheostat(? current control) I assume goes in series with the TEC so I can adjust the dT produced, but there probably needs to be some sort of 'balancing' in the circuit or else the current to the fan would go up as the TEC is turned 'down', causing the fuse to blow...
My basic circuit idea is attached, please comment and suggest what other 'bits' are needed to make this idea work...
