Help needed restoring a slot machine topper
joeyanyc
Oct 23, 2013
Oct 23, 2013
Hey gang, I picked up a few toppers that I want to restore. Unfortunately, I don't have the slot machines that they go to, however they are hard to get so I grabbed them when I saw them.
Anyway, I would like to know how to light them up to see what bulbs needs to be replaced. I don't know a thing about these, so I will post a few photos and see what you can come up with. If you need any more specifics, ask and I will see what I can read from the boards on this.
Keep in mind, I'm a total newbie...so thanks in advance. Here's my first topper to restore.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
What's a "topper"?
joeyanyc
Oct 23, 2013
Oct 23, 2013
They are the top parts of the slot machines. They are normally powered by connecting to the slot machine. I want to be able to power mine without the slot machine.
(*steve*)
25,510
25,510
Doh! I was thinking pinball for some reason.
JimW
Oct 22, 2010
59
Oct 22, 2010
59
Never done slot machines. But more than one pinball machine and a few antique ones. Can't be too difficult. First thing is to become a expert searcher on Google, amazing what you can find in the way of schematics and info.
But if you want to brute force it, here goes:
- Remove one of the lamp holders and see what is inside. Light bulb or an LED? If it is a light bulb, figure out the voltage by using a variable power supply or a few 1.5 volt D cells in series. Most likely 6.3V.
- Trace the connections from the open lamp socket back to your connector. You should find two connections (one for the hot and one for ground).
- Put the lamp back in and apply power to the two wires you identified. See how many lamps light up.
- Pick one that didn't light up and repeat the previous 2 steps. Probably will have the same common wire and a different hot wire. A lot of back panels have groups of light bulbs that operate as a set. Identify all the sets and you are good.
Note that if you have an LED back panel you will need to worry about a few more things, but based on your picture I am betting on light bulbs. Hopefully all of the control circuitry is elsewhere and your panel is just bulbs. If so, this should work.
JimW
JimW
Oct 22, 2010
59
Oct 22, 2010
59
Sorry, a bit more info.
Use a voltmeter to trace the lamp connections back to your socket. Use the Ohms scale and look for dead shorts.
The problem is a with a lot of lamps in parallel, the filament resistance starts looking like a dead short. You might need to experiment a bit.
Jim
