Hello all ..,
I got an Sony Crt Tv (model number - KV-G21B1) and i found its damper diode is short. Then, I replaced it with a new diode (with same number as the old one) and after trying to turn on the Tv, the indicator led turns On and Off continuously with all the voltages of the board turning On and Off repeatedly. Then I found that the new damper diode I replaced was also short. I tried with few diodes but all of them became defective. I couldn't find the reason behind damaging the damper diode repeatedly and the following are the things I did with the TV board.
Please support me to solve this problem and I am clueless in this case to repair this Tv.
Thank You very much for your time.
- Resoldered all the dry joints including the Neck Card.
- I found the 33v zenar diode is short at tuner and replaced it.
- All the suspicious mylar capacitors are replaced around the H-OUT section.
- Replaced the flyback transformer but nothing changed.
- I checked the HOUT and VOUT transistors and they are fine.
