L
Lambing Flat
G'day all
I am very much a beginner at this electronics lurk so I am hoping that
someone can help me figure out what is wrong with my version of the
circuit shown in the following diag.
http://www.trainweb.org/toenailridge/circuit.jpg
The circuit's function is to smoothly accelerate a G gauge battery
powered locomotive to running speed once the circuit is turned on, and
then to smoothly decelerate it back to stop once the circuit is turned off.
My problem is that it accelerates very nicely to speed in about 3 secs
once the switch is turned on, but when the switch is turned off it takes
about 2 minutes to stop! I have obviously done something wrong, as the
deceleration is supposed to be at the same rate as the acceleration, but
I can't figure out what my mistake is :-(
Here are photos of both sides of my version of the circuit, (apologies
for my poor standards of soldering ;-)
http://www.cia.com.au/bullack/Circuit1.jpg
http://www.cia.com.au/bullack/circuit2.jpg
The only difference my version has to the circuit diagram is that I have
temporarily moved the connection to the base tag of the MOSFET from the
"power always" side of the on/off switch to the other side, as part of
ongoing experiments to try to find out why it won't slow down! Made no
difference at all, I'm afraid......
I have carefully checked all other connections and components, and as
far as I can tell, (other than as mentioned above) everything is
connected and in the correct place and there are no shorts.
As part of my careful checking of everything I have established that the
batteries produce 7.5v and that is the voltage present at the collector
leg of the MOSFET once the switch is turned on and the circuit powers
up. The voltage drops to 5v on the emitter leg of the MOSFET.
Hopefully the fine brains trust here will be able to point me in the
right direction!
James McInerney
My G gauge garden homage to the now long gone railways of Tasmania's
west coast, the "Rurr Valley Railway"
http://www.cia.com.au/bullack/rvrtitle.html
also http://www.cia.com.au/bullack/ , where the steam era NSWGR
secondary lines live on in HO at bucolic "Lambing Flat"
and http://members.optusnet.com.au/lambingflat/ for the family stuff!
right direction!
James McInerney
