Help needed and appreciated Battery powered heat source
Discussion in 'Power Electronics' started by aaronshirk, May 20, 2013.
  1. aaronshirk
    aaronshirk
    6
    May 20, 2013
    Hello everyone,
    My name is Aaron. I am not very familiar with electronics but I have something I want to put together. It should be relatively simple and straight forward.
    I want to make basically a small battery operated heating pad (best way I know how to describe it).
    It needs to be at least 10" long and around 4" wide. It needs to give off some heat but doesn't need to be real hot or anything.
    I am making a pad that I can heat my camera lens with so that it doesn't draw moisture while shooting startrails and timelapses at night.
    Any help and or suggestions would be appreciated
    Aaron
  2. CDRIVE
    4,960
    652
    May 8, 2012
    I'm sure that something is already commercially made and I don't think you can make one cheaper.
    Chris
  3. aaronshirk
    aaronshirk
    6
    May 20, 2013
    I have done a quick search and have not really found what I want
  4. (*steve*)
    25,497
    2,838
    I think we need to wait for Davenn to see this thread...
  5. davenn
    davenn Moderator
    13,836
    1,951
    Hi Aaron
    welcome to the forums :)
    dew shields are very common for schmitt cass. telescopes ... havent seen one for a camera lens, but the principle is the same.
    It really only needs to be big enough to encircle the very front of the lens
    so what is the circumference of the lens ? .... put a tape measure around it
    It would need to protrude out from the front of the lens 2 or 3 inches.
    here's one site with some construction details ....
    http://www.myastrospace.com/DIY_Dew_Heater.htm
    cheers
  6. CDRIVE
    4,960
    652
    May 8, 2012
    Dave, that's a shocker! Are you saying they're not commercially made?
    Chris
  7. davenn
    davenn Moderator
    13,836
    1,951
    there are some commercially made for telescopes
    but hell its still much cheaper to make it yourself
    I still havent got around to making one for my own scope .... just another thing on the list to do :rolleyes:
  8. aaronshirk
    aaronshirk
    6
    May 20, 2013
    Thanks so much
  9. aaronshirk
    aaronshirk
    6
    May 20, 2013
    any suggestions on the controller that they were referring to?
  10. davenn
    davenn Moderator
    13,836
    1,951
    depending on the current being drawn, you could use a wire wound variable resistor
    ( if less than ~ 300mA)
    otherwise maybe a variable power supply. Varying the voltage out will vary the current through the resistors and therefore how much they heat up.
    I have just run out of time ...some one else may show you a circuit for that maybe using a LM317 adjustable voltage regulator .... Im heading out to work now :)
  11. aaronshirk
    aaronshirk
    6
    May 20, 2013
    thanks
  12. CDRIVE
    4,960
    652
    May 8, 2012
    They also recommended a car or motorcycle battery. Is that in your plans?
    Chris
  13. aaronshirk
    aaronshirk
    6
    May 20, 2013
    yes I am planning on using an automobile or motorcycle battery (probably motorcycle due to size and weight)
  14. CDRIVE
    4,960
    652
    May 8, 2012
    Google "LM317 Data Sheet". It should include a typical adjustable voltage output circuit.
    Chris
