Help needed - Amdeco 20P/ Napco 2WAY-UNIVKF
Discussion in 'Security Alarms' started by [email protected], May 5, 2004.
  1. Guest
    I have tried following installation instructions for an Ademco Vista-20P
    and a Napco 2WAY-UNIVKF keyfob/receiver to no avail. I am trying to use it
    in bus mode and cannot get the receiver enroll mode LEd to flash rapidly.
    Is there something I am missing? Thank you in advance for any aid in
    resolving this.
  2. G. Morgan
    G. Morgan Guest
    Someone named Proclaimed on Tue, 04 May 2004
    20:41:48 -0400,
    Are the "panel type" jumpers set correctly?
    j3=off
    j4=off
    j5=on
    The following procedure is used to enroll the unique RF ID number
    stored in the non-volatile memory of each KeyFob into the receiver
    memory.
    1 Arm system from any keypad
    2 Disarm system from any keypad
    3 Press 1114, then [AWAY] on keypad
    The Enroll Mode LED will flash rapidly.
    The keypad may sound error beeps* - ignore.
    SELECT * FROM users WHERE clue > 0
    No results found in alt.security.alarms
  3. Guest
    The system configuration jumpers have only #5 connected.
    My "Enrolling Keyfobs" (page 9) lists 1114 STAY (3 key) as the sequence to
    get the Enroll Mode LED to flash rapidly, I tried 1114 OFF (2 key) but it
    still will not flash. (Both codes entered after an are/disarm sequence)
    Does the 20P have to be programmed in any manner to get to this
    flashing step?
    Thank you
  4. Someone named Proclaimed on Mon, 10 May 2004
    20:45:57 -0400,
    The OFF key is "1" the AWAY key is "2"
    Press 11142
    Are you sure it's a Vista 20???
