Help!, Need ECG / NTE 1546
Discussion in 'Electronic Repair' started by john, Oct 19, 2003.
  1. john
    john Guest
    What is the original number that converts to NTE1546.
    kip
  2. Marvin Moss
    Marvin Moss Guest
    NTE does not list a NTE1546 as a valid number???
  3. The original part number is STR381.
  4. STR729 is a sub... according to www.pacificsemi.com they might have
    them in stock. Or www.mainelectronics.com as another possibility.
    It is only a voltage regulator, you should be able to adapt another
    voltage regulator to do the job with a bit of understanding of the
    current and voltage required in the end...for example if you add a
    zener to the ground reference of a regulator you will raise the output
    voltage by the amount of the zener...assuming the ground reference is
    not passing more current than the zener can safely handle! there are
    better tricks, but this is simply one of them...
    John :-#)#
    (Please post followups or tech enquires to the newsgroup)
    John's Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9
    Call (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, Video Games)
    www.flippers.com
    "Old pinballers never die, they just flip out."
  5. S Walters
    S Walters Guest
    I am looking for the above listed part. It is a voltage regulator in a TO3
    style case to fix an older (80's) Teknica color TV Model # 3749. I have
    been told by my local parts supplier that this part is no longer available.
    Does anyone know where I can get this part? Is it truly obsolete? If so,
    this would be a waste of an otherwise good, repairable 19" color TV. I am
    fixing this up for a co-worker who cannot afford a new set so I would really
    like to get it going. I also need a degaussing thermistor for this set or
    info on a universal replacement. Please help as I really want to make this
    set available to someone who really needs it.
    Many Thanks,
    Steve
  6. Jim Adney
    Jim Adney Guest
    Do you know the voltage of the original part? If so, you can often
    replace TO-3 case parts with TO-220 parts. Thus a 7815, for a +15V
    example, might be exactly what you need.
    If you need more current than the 7800 series can provide, you can use
    an appropriate bipolar transistor with a resistor and zener on the
    base, to give you virtually the same functionality. The temp comp may
    not be as good, but I gather you are desperate.
  7. Bill Jr
    Bill Jr Guest
    ECG/NTE 1546 is a cross from a STR381 as far as I can tell.
    It would probably be an acceptable possibility to replace that device with a
    STR30130 or STR3130.
    The device is no where near the same size or configuration, but with a bit
    of engineering you can probably make it work.
    Good Luck,
    Bill Jr
  8. Jack
    Jack Guest
    What is the original number on the device?
