W
Wayne Kerr
I recently had to replace the pump on my washing machine as the old
pump was randomly failing to start. On examining the old pump I can find
nothing wrong with the impeller mechanism, which leads me to believe its
probably the small capacitor (used for starting the pump? - it has no
brushes). Does anyone know if this could be the likely reason and if so
what rating of capacitor should I replace it with if I experience a similar
problem in future? The only data shown on the body appears to be a part
number, no microfarad / voltage rating is shown - an approximate rating
would be a good start, I could then experiment until I get it right. PS its
a 230/250 volt machine if that makes any difference.
