jeremealmore
- Aug 25, 2010
- 2
- Joined
- Aug 25, 2010
- Messages
- 2
Dear All ,
I was trying to measure the resistance of an Epoxy coated Tungsten Microelectrode using a HP Multimeter.
The electrode length is 135mm and diameter is 200 micrometer.
Both tips are stripped of epoxy insulation.
When I tried to measure the resistance directly (by touching the multimeter leads on both ends ) , the multimeter showed "0L"
Then I tried putting the electrode to some depths of saline and placing another needle along with it and then touching the multimeter leads on electrode and needle. Again the reading was "0L"
I tested the multimeter with known resistances and needles/wires higher diameters and its working well !
I googled a lot to find any theoretical problems associated with measuring the resistance of such fine microelectrods with multimeter . I couldnt find any definite answer .
[The ideal resistance of the microelectrode is 10 mega ohms as per the company catalouge, but i need to test it atleast for some]
Can anyone help me in this issue ? Is there any theoretical problems associated with this measurement ? If so what can be an alternative method ?
Please help !!!
Please help !!!
