Help me with LIN regulator Tester
Discussion in 'General Electronics Discussion' started by Nikhilesh D R, Aug 30, 2016.
  1. Nikhilesh D R
    Nikhilesh D R
    Aug 30, 2016
    I do not have much knowledge in electronics, but I can understand the thing,and know some arduino basics..
    I was given a project about to test the 'LIN regulator'
    LIN-local interconnect network is controlled alternator-regulator for next-generation vehicles.
    I basically understood about this is that ,the output voltage is dependent on digital input given to that..
    All I need is how to construct the circuit, I have searched the internet there is nothing related directly to it.
    I want to build something like this(Ad50 Autodiagger 50)....
    And I have all the required data of LIN regulator like specification and data sheet...
    This is my first project and need a start, just give the idea on how to work on this and build a working circuit.
    positive replies will be appreciated...
  2. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    "I do not have much knowledge in electronics, "
    This is way beyond you.
  3. Nikhilesh D R
    Nikhilesh D R
    Aug 30, 2016
    At least just guide me through, and you didn't notice "but I can understand the thing".......
  4. Herschel Peeler
    Herschel Peeler
    401
    65
    Feb 21, 2016
    So it is a learning experience. Help him learn.
    Can you post the data sheet for the part or give us a part number we can find?
    General comments ...
    Simulate the working environment the device is used in. Input voltage. Output load ...
    What specifications must be met?
    Beyond you? Take it one step at a time. Form specific questions and find answers.
    (*steve*) likes this.
  5. Herschel Peeler
    Herschel Peeler
    401
    65
    Feb 21, 2016
    Application notes are helpful.
    http://cache.nxp.com/files/analog/doc/app_note/AN4289.pdf?pspll=1
    The LIN alternator regulator family of devices is specially designed to work in adverse
    environments. It supplies a current through a high side MOSFET to the excitation coil of the alternator and provides an internal freewheeling diode. It’s main functionality is to keep the battery at its nominal value, whatever the vehicle demand. The protection and diagnosis may be programmed using OTP (non-volatile Memory).
    Additionally, these devices have a fail-safe mode for continuous battery charging in the event LIN is disconnected.
  6. (*steve*)
    25,482
    2,830
    I really need to review each and every post by Colin. Sorry @Nikhilesh D R that I didn't do that earlier. He was being typically unhelpful.
