This is an assignment, right? I therefore put it into the homework forum.
- Start by assigning one JK-FF to each output A, B and C. Assume that upon reset all flipflops are set to Q=0, \Q=1 (typically you will have to provide a separate reset signal for this to happen).
- Define which of the states in your truth table is the initial state after reset. Chose Q or \Q from teh flipflops as outputs A, B and C such that these outputs represent the initial state after reset.
- find the logic equations (boolean equations) that define the next output state (A(t+1), B(t+1), C(t+1)) in terms of the current state (A(t), B(t), C(t)) and using this find the equations how to set up the J and K control inputs such that the JK-FF will change to the desired state with the next clock.
Here are
some examples how the flipflop's outputs plus some logic can be used to create diffferent behavior. Show us your effort for a sanity check.
