Help identifying transformer
Discussion in 'Troubleshooting and Repair' started by Dan Geddes, Nov 3, 2014.
  1. Dan Geddes
    Dan Geddes
    Nov 3, 2014
    Help
    Have a transformer that cooked on a electric range contol board but am unable to identify it
    LTE i believe is "Li Tone Electronics Co Ltd."
    the label on it
    909-273
    LTI 0210
    it burned quite a hole in the board but did not seam to effect any of the traces ... unless there was a fuse there that vaporized... LOL
    any help would be appreciated
    http://www.digikey.com/techxchange/servlet/JiveServlet/showImage/2-15013-27948/pic+1.jpg
    http://www.digikey.com/techxchange/servlet/JiveServlet/showImage/2-15013-27949/pic+2.jpg
    http://www.digikey.com/techxchange/servlet/JiveServlet/showImage/2-15013-27950/pic+3.jpg
  2. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Hi Dan and welcome to Electronics Point :)
    I don't think there's anything wrong with that transformer. It looks like the circuit board has burnt up somehow, and deposited some black gunk on the wires on the underside of the transformer. The wire isn't damaged and show no signs of overheating itself.
    You'll need to clean the circuit board and cut or grind out any material that's discoloured; even slightly. Take photos first so you know what needs to be connected to what.
    Do you know what caused this problem? Is it possible that something dripped onto the board? What does the underside of the board look like?
