Help identifying SMD diode
Discussion in 'Datasheets, Manuals and Component Identification' started by Daybear63, Jul 21, 2020.
  1. Daybear63
    Daybear63
    3
    Jul 21, 2020
    By a stupid mistake i managed to hook up my Tomtom XXL to 12v and blew a SMD diode on the pcb. I borrowed a XXL from a friend and could see the diode was marked B, but i could not find any info on that particular SMD diode. Could someone help me to identify this diode or suggest a equivalent replacement? DSCN3221.JPG
  2. Martaine2005
    Martaine2005
    3,415
    928
    May 12, 2015
    How did you do that?
    This link should give you the diode plus some substitutes.
    From here.
    Martin
  3. Harald Kapp
    11,444
    2,629
    @Martaine2005 : A BAP50 as in your link is a RF pin diode in a SOT-23 case. This is not what @Daybear63 is looking for. An SOD323 or similar is required.
    From the catalog a BAS16-03W matched the code and the case.
    However, given that SMD markings are so short due to the small case sizes this is not an unambiguous resolution to the question. Without access to a BoM or a schematic (both probably not available to the public) I think no definite answer can be given. Sorry :(
    Anyway, I wonder if this is the only component that was destroyed by that unlucky connection to 12 V. I suspect more components will have taken a blow.
    Martaine2005 likes this.
  4. Daybear63
    Daybear63
    3
    Jul 21, 2020
    Thank you for your input:) The unit charging light turns on when i connect power but the unit itself would not turn on. The diode is not conducting. So i had a small hope that the only component blown was the diode.;)
  5. Daybear63
    Daybear63
    3
    Jul 21, 2020
    I do not know if it helps but here is a full size image of the pcb. Uten navn-1.jpg
  6. bertus
    bertus Moderator
    1,762
    677
    Nov 8, 2019
  7. Martaine2005
    Martaine2005
    3,415
    928
    May 12, 2015
    That’ll teach me to link from a description.
    My link gives an extra leg free!.
    Martin
