help identifying part
Discussion in 'General Electronics Discussion' started by whistlekleen, Jan 25, 2016.
  1. whistlekleen
    whistlekleen
    6
    Jan 25, 2016
    I'm new to electronics and basically teaching myself. I'm trying to diagnose an issue with a particular boarding and I'm not sure what these components are, or their function. It's the very small almost diode looking part. Thsnks
  2. Minder
    Minder
    3,093
    663
    Apr 24, 2015
    The Q designation are transistors, the 2 pin designated R are resistors C capacitors.
    M.
  3. whistlekleen
    whistlekleen
    6
    Jan 25, 2016
    The transistors and resistors are labeled, the capacitors are not..how do I know what the capacitance is supposed to be?
  4. Supercap2F
    Supercap2F
    550
    150
    Mar 22, 2014
    You can't really tell their capacitance unless you desolder them and measure them with a multimeter. SMD capacitors can be a real pain sometimes...
  5. whistlekleen
    whistlekleen
    6
    Jan 25, 2016
    I didn't realize capacitors were made that small...do these ones puff and leak like the larger ones. If I take them out of circuit to test them it's going to be a real pain and I have no idea what the capacitance is supposed to be to know if they are good or bad..any tips or tricks on how to go about starting to diagnose a circuit? Or is it just go at it and test everything?
  6. whistlekleen
    whistlekleen
    6
    Jan 25, 2016
    Also, what can be tested in circuit and what can't?
  7. davenn
    davenn Moderator
    13,836
    1,951
    to be tested reliably, most parts would have to be removed
    and for a beginner, as yourself, this would almost be guaranteed to destroy them
    so what is the unit and what is wrong with it ?
  8. whistlekleen
    whistlekleen
    6
    Jan 25, 2016
    I've done my fair share of removing components from circuits and testing and putting back. I've fixed a few power supply boards for tv's and such. What I'm working on here is a motor controller for a treadmill. I've already replaced the board so I know it is the issue and it just gives an error. I just wanted to play around with the old one and see if I could rebuild it.
  9. davenn
    davenn Moderator
    13,836
    1,951
    SMD's are a whole different ball game compared to legged components ;)
  10. whistlekleen
    whistlekleen
    6
    Jan 25, 2016
    Yeah now that Ive done some research I see its quite different. Almost seems a little impossible for a simple hobbyist to do at home
  11. IamJatinah
    IamJatinah
    16
    Oct 28, 2014
    Hi There...this is the upper control (brain board) of the IFT AC Variable Drive, made by Advanced Drive Technology.
    Your version of software shown relates to the Precor 932 Treadmill....yes?
    DO NOT TOUCH those surface mount parts unless you want to kill that control board ;o) I know exactly what's wrong with your board....but I cannot place that info into this public forum for a couple of reasons. I will tell you that your fix has nothing to do with surface mount parts unless it was a catastrophic failure, which I see few of....you can contact me privately for help with it or if you'd like a replacement upper board for your IFT drive as we have both complete drives and boards for them and various software versions. (jatinahATrocketmailDOTcom)
    Have a great day!
