Help identifying mosfet
Discussion in 'Electronic Repair' started by Gintby, Jan 12, 2007.
  1. Gintby
    Gintby Guest
    I've been asked to look at a Genius G-12-060 12V 600W inverter
    (http://www.atlantasolar.com/product_info.php/name/G-12-060 12V%
    20600W/products_id/416).
    All 6 of the mosfets(?) have failed short circuit.
    It may not be worth the effort of actually repairing; but just for
    giggles I've removed them and I'm trying to find a suitable replacement.
    The devices are TO-220 are simply are marked:
    F N334AN
    The F doesn't look like a Fairchild F, but it appears to be seperate from
    the part code.
    Anyone have any ideas? or any guesses as to what the missing suffix could
    be?
  2. Meat Plow
    Meat Plow Guest
    If it's an N channel device it would probably be fine to replace it with
    Fairchild part number RFP45N06. Specs are 50 amps at 60 volts and they are
    just a buck or two each. Not knowing jack about your device brand but
    working on others I've repaired were all N channel enhancement mode fets.
  3. Gintby
    Gintby Guest
    That's the big *if* though. I'm not even sure they are mosfets....(but
    I'd be surprised if not).
