help identifying F10A60
Discussion in 'Electronic Components' started by Gary Woodruff, Mar 11, 2011.
  1. Hello all i am trying to cross a transistor or diode that is marked with:
    N4c
    F10A60
    (diode symbol)
    it is from a power supply from a LCD TV and located near the rectifier.
    It is a TO220 case with the middle lead clipped off in the circuit. It
    is shorted between pins 1-3 so I cannot give you a voltage drop or any
    other useful info.
    Thanks, Gary
  2. Franc Zabkar
    Franc Zabkar Guest
  3. Jamie
    Jamie Guest
    High speed switching diode ?
    10 amps,60 VOlts ?
    Jamie
