Help identifying an IC
Discussion in 'Datasheets, Manuals and Component Identification' started by iTQAN, Dec 19, 2013.
  1. iTQAN
    iTQAN
    3
    Dec 19, 2013
    I need to find a replacement or specs for the IC thats shown in the attached image.
    Here's the details:
    I'm working on repairing a controller circuit for a frequency up-convertor. I replaced 2 voltage regulators and that fixed the problem partially. The circuit runs for 10 minutes and then alarms with power supply fault (not a hard fault). I traced the problem and I found that the IC shown on the attached image is faulty. I researched the numbers on the IC with no luck finding any info. Any help, tips or ideas to help me out find a suitable replacement would be much appreciated.
  2. Harald Kapp
    11,644
    2,691
    Without assuming any warranty, it could be this part: DS1809
  3. iTQAN
    iTQAN
    3
    Dec 19, 2013
    I'm going to call them tomorrow to verify the numbers. Thank you very much.
  4. davenn
    davenn Moderator
    13,865
    1,956
    can you verify that the top left pin ( in your pic) goes to supply ... should be 5V + - 0.5 V .... that will possibly confirm it being a DS1809
    What makes you think that that chip is faulty ?
    Do you have a good understanding of the circuit ? would a DS1809 digital potentiometer be a realistic IC to be in that position ?
    cheers
  5. iTQAN
    iTQAN
    3
    Dec 19, 2013
    Hi Dave,
    I have 3 of them on the circuit and 2 are suspected faulty. The first one works as a digital potentiometer controlling L2941LD surface mount. This one has thermal issue it faults below the specs temp.
    Here's a similar digram: http://www.maximintegrated.com/app-notes/index.mvp/id/183
    The other one I'm not sure what it does. I didn't have enough time to examine it fully, but pin 1 should show voltage of ~1.25 and thats what I'm seeing on the other 2 DS1809, instead of being shorted to the ground. I'll do more digging and measuring on Monday.
    I also contacted Maxim Integrated and am waiting for them to get back to me to verify letter x on the first line and the numbers on the 2nd line.
    Ahmed
  6. davenn
    davenn Moderator
    13,865
    1,956
    OK cool
    thanks for that link ---- informative :)
