I know this is an old thread, but I am trying to identify the same resistor which came out of... wouldn't you know it.... an lcd tv power board. Namely, a Vizio 47" lcd with model #: SV470XVT1A.
Did anybody ever figure out what manufacturer these resistors are from? The symbol looks like it says FD or HJ or maybe an asian language letter. I havent had any luck searching the web for these and other letter combos.
In addition, another resistor near it blew also which has markings:
(manufacturer symbol) (space) 80X
and
2WJ
and
.7? (omega)
I believe the 2WJ are industrial markings for power dissipation and tolerance: this one being 2 watt 5%. But Im not sure.
Unfortunately on BOTH resistors, the area where the resistance value is printed cracked off or vaporized or something so I can only read the first digit. One reads .1? and the other reads .7?. You can tell there was another digit there on both because you can still see the edge of the ohm symbol on both.
These are high temp carbon-film resistors, not fuses. The manufacturer shouldve used higher wattage resistors because testing shows nothing else wrong with the circuitry. The resistors just overheated and blew.
But please, if anybody thinks they know who the manufacturer is (or the wattage, tolerance, and resistance) it would help me greatly.
