I have a handful of these motors. They are all pretty much the same.
They spin around when 12V dc is connected.
They have and encoder on the back.
What type of encoder is this called, I assume it is a magnetic pick up encoder. So you would supply power to the encoder wires RED, WHITE, BLACK. Then as the shaft spins and the disc passes through the gap that has a magnetic field, it must detect some inductance pulses? Then this would be what you then wire up to an IC to use the pulses to count??
I'd like to find out what I have and what the specs are and if I can use it for a small project, ie will it have enough torque etc.
