Help identify electronic components
Discussion in 'Troubleshooting and Repair' started by ASHWIN.R, Nov 20, 2016.
  1. ASHWIN.R
    ASHWIN.R
    5
    Nov 20, 2016
    hi
    I have a resistor which has a colour code that reads
    orange, orange ,sliver,gold,black
    but I don't know what value it should be .
    I found it in a power supply board,
    it gives me a reading of 0.5 ohms with my multimeter
    can someone help me identify what it's value should be
    thanks
  2. Heliman
    Heliman
    65
    13
    Feb 4, 2016
    Its .33 Ohm
  3. ASHWIN.R
    ASHWIN.R
    5
    Nov 20, 2016
    does this mean that the resistor is faulty
    thanks for the reply
  4. Heliman
    Heliman
    65
    13
    Feb 4, 2016
    Are you testing the resistor out of circuit? What kind of ohm meter are you using? What makes you suspicious of this resistor?
  5. ASHWIN.R
    ASHWIN.R
    5
    Nov 20, 2016
    yes I am testing the resistor out of cct and am using a FLUKE 114 multimeter.
    The reason I think that the he resistor is bad is because with the multimeter it gives a reading of 0.5 omhs,
    it's connected to a STR (W6053s)
    thanks
  6. davenn
    davenn Moderator
    13,347
    1,774
    close enough at such small values
  7. ASHWIN.R
    ASHWIN.R
    5
    Nov 20, 2016
    thanks guys for the help.
    it turns out that the resistor is good after all , I found out that a couple of GBJT was shorted
  8. 73's de Edd
    73's de Edd
    2,743
    1,131
    Aug 21, 2015
    I did not NOT look up to see if the 114 has ohmmic nulling compensation.
    BUT if not . . . . . on reading LOOOW values like that in the future.
    Plug and unplug your probes into the meter.
    Clean the probe tips of all oxide .
    Then place in the low range ohms and short together your probe tips and thereby you are measuring your induced, total lead and connector resistance error.
    Remeasure your resistor, but this time, factor in those resistance errors, by subtracting them from the displayed resistance being read out..
    73s de Edd
