Help identify a dual modulus PLL IC
Discussion in 'Electronic Components' started by MarkAren, May 13, 2007.
  1. MarkAren
    MarkAren Guest
    Hi all,
    It's marked D3827G002 in a 16 pin SOIC and is used in an AMPS RX chain
    Pins identified so far:
    PIN 1 Ref / 64
    PIN 2 Ref / 64
    PIN 3 Clock Data or Strobe
    PIN 4 Clock Data or Strobe
    PIN 5 Clock Data or Strobe
    PIN 6 5V
    PIN 7 REF IN (15.36MHz)
    PIN 8
    PIN 9
    PIN 10
    PIN 11
    PIN 12
    PIN 13 GND
    PIN 14 From Prescaler (?)
    PIN 15 Modulus Select out (?)
    PIN 16
    Date code is around 1990.
    Any pointers to a data sheet or a programming guide will be most
    welcome.
    Mark.
  2. Franc Zabkar
    Franc Zabkar Guest
    FWIW, it's probably an NEC uPD3827G-002.
    - Franc Zabkar
