Help ID connector, 3pin, .1", shell, w/pic
Discussion in 'Electronic Design' started by Ben Jackson, May 27, 2007.
  1. Ben Jackson
    Ben Jackson Guest
    Can someone ID this connector? I've tried every connector manufacturer
    I can think of, although some have atrocious websites and I might have
    missed it.
    It's white, 3 pin (also need the 4 pin version), .1" / 2.54mm spacing,
    slight 'D' to key it with slight ridges between pins. The side is
    slotted.
    http://ad7gd.net/misc/what_connector.jpg
    That's a vertical mount, I want right-angle. That one has 'MXT 9'
    or possibly 'MXT 8' on the back. The RA one has 'MXT 24'.
  2. Ben Jackson
    Ben Jackson Guest
    Actually it was 2.50mm spacing (0.98")
    And what I thought was the date code, which after peering at enough
    of them I figured out was `5268'. It's a Molex Mini-SPOX wire-to-board
    header p/n 22-05-7035 and -7045 (for the 3/4 pin RA versions)
    http://www.molex.com/catalog/pdf/MX5268-NA.pdf
    Of course I figure this out right after finalizing a Mouser order.
