clivcroucher
- Jan 11, 2012
- 2
- Joined
- Jan 11, 2012
- Messages
- 2
Hi all
I have a small project which is driving me nuts! OK I bought my two boys a slot racing set for Xmas. Its a small set that just unfolds in a case, plug in two controllers and your off racing.
The controllers are hand powered, as in turning a handle generates the voltage in a simillar way to the hand powered torches out there. One of my boys has cerebral palsy and he cannot rotate the handle fast enough to generate enough power to keep the car moving round the track.
So..........I though easy solution, I'll make a battery powered hand controller for him that he can simply turn a knob on to increase the speed of the car.
I measured the voltage and current being used, a bit hit and miss but something in the order of 3 - 9v @ around 0.5 amps.
Here's my difficulty..........I cannot find a rheostat or pot that will work with this low DC voltage. I'm in the UK and have tried the major retailers for these parts. it is driving me insane! Not even Ebay has come up trumps.
So my question........can I achieve what I set out to? Is there a better way to do it?
Obviously I do not want to spend a fortune on expensive parts......I thought I would crack this for less than £10.
Any help wuould be much appreciated.
Clive
Clive
