help for installing hspice
Discussion in 'General Electronics Discussion' started by dariush, Jul 2, 2013.
  1. dariush
    dariush
    6
    Jun 26, 2013
    hi
    i installed hspice2004 but i cant find the exe file.(windows7 32 bit)
  2. donkey
    donkey
    1,293
    56
    Feb 26, 2011
    http://www.synopsys.com/Licensing/Installation/Documents/install072/hspice_install.pdf
    hope this helps somewhat.
    we deal more with electronics and coding than IT stuff
    unless we get a good look at where you went we won't know where to look.
    there are common things though, try to search for it in the windows bar, check program files where most common installs go, check the file system hasn't hidden any folders or files... the list goes on.
    if you can find your install directory that'll be a good start
  3. (*steve*)
    25,496
    2,837
    One thing I do is try to install a package again. Most will give you the choice to select a directory (and you've probably installed it in the default one) and you can use this to tell you where you installed it :)
