Help for designing MIL-STD 1553 boards.
Discussion in 'Electronic Design' started by [email protected], Sep 6, 2005.
  1. Guest
    hi all
    Hope this is the correct place to post this message.
    I need help from some one who did MIL-STD-1553B projects. I am new to
    designing area.
    Can some one show me the path of how to design a board with ms1553B to
    interface at least 10 serial port sensors?
    I have studied 1553b tutorials available in net , most of which give
    info on only protocol concepts but not on design aspects and design
    hardware.
    Thanks in advance.
    Manohar
  2. Tim Wescott
    Tim Wescott Guest
    1553 can be a real bitch to design to and get certified -- to the point
    where all of the (few) devices that I've seen just buy a module from one
    of a few vendors, and interface to the module to actually get information.
    Unfortunately I can't remember the name of the companies who are big on
    selling the modules -- but this may point you in the right direction.
  3. Jim Thompson
    Jim Thompson Guest
    Several different hybrid houses... National Hybrid, Aeroflex, Microrel
    (may no longer be in the business), Device Engineering Inc (chips
    only), DDC, etc.
    Chips by yours truly ;-)
    1553 is NOT for amateurs... many ways to get bitten.
    ...Jim Thompson
  4. DDC
    http://www.ddc-web.com/
  5. Bob Stephens
    Bob Stephens Guest
    We use one from ILC Data Device Corporation Their website www.ddc-web.com
    also has lots of 1553 design guides, application notes etc.
    Another outfit that sells IP FPGA cores is Condor Engineering.
  6. Mine was when the customer insisted that their interface was floating
    balanced pair, and the returns were actually grounded.
    Had to show them their own schematic.
    Our chips got hot pumping signals into ground, but worked anyway.
  7. Guest
    Thanks for the reply.
    we are into building a single board solution in which we interface with
    ten serial communication ports of RS-232 and also 4 USB interfaces.
    All this with M-S-1553B standard implemented into it.
    Presently I am studying various aspects and feasibility of designing
    this. Latter a better approach will be considered.
    Can some one please give details of design using processors for MS1553B
    boards.
    manohar
