help fixing netgear switching adapter
Discussion in 'Troubleshooting and Repair' started by pharaon, Jan 27, 2016.
  1. pharaon
    pharaon
    378
    6
    Oct 28, 2014
    the electricity went off suddenly and since then the router keep rebooting
    the output volt now is : 13:90
    current 5.2
    i think it should be 1 A
    any one have an idea how to fix
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. (*steve*)
    25,482
    2,830
    If you measured the current directly across the power supply then you were:
    a) doing it wrong
    b) risking damage to both your meter and the power supply.
    Try finding another 12V 1A adapter and see if the router works with that.
  3. pharaon
    pharaon
    378
    6
    Oct 28, 2014
    i did and it work just fine although its 12v but 0.5 A
  4. Cirkit
    Cirkit
    132
    10
    Oct 28, 2015
    You can continue to use the 12V 0.5A PSU and your router will probably work just fine. If you really want to repair the original PSU, I suggest you start by measuring the blue 1000µF capacitor which corresponds to the burn marks on the other side of the PCB and R18. Does your multimeter measure capacitance?
  5. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    This is a classic case of
    "don't fix it, it ain't worth the time or money" .
    Just get a new one ,it is dirt cheap,here
  6. pharaon
    pharaon
    378
    6
    Oct 28, 2014
    R18 = 1.7 K
  7. pharaon
    pharaon
    378
    6
    Oct 28, 2014
    i fix it thanks every one
