conductor3
- Jun 7, 2011
- 84
- Joined
- Jun 7, 2011
- Messages
- 84
i need to find a transistor that can conduct 110 volts (dc converted with NTE5322W bridge rectifier) across the emitter and collector and can be turned on with 5 volts (microcontroller voltage) on the base i dont care if its npn or pnp i dont mind throughing in a couple 4049s
to change the positive to a negitive
thank you
- kevin
thank you
- kevin
