Help finding a switch
Discussion in 'General Electronics Discussion' started by Jbatts39, Jul 24, 2017.
  1. Jbatts39
    Jbatts39
    4
    Jul 24, 2017
    I just need a website to order a tiny click on, click off type switch. It will be mounted in a ring so it has to be super tiny.
    Anyone know where I can find something like that?
  2. 73's de Edd
    73's de Edd
    2,922
    1,235
    Aug 21, 2015
    Sir Jbatts39 . . . . .
    Not knowing the mounting relationship position on the "ring" nor its size, how much BIGGER can the switch be, than the one being shown ?
    73's de Edd
  3. Jbatts39
    Jbatts39
    4
    Jul 24, 2017
    Well that one would be great but I would say no bigger than 3mm
  4. ChosunOne
    ChosunOne
    373
    91
    Jun 20, 2010
    How do you work that switch?! Trained ants?
  5. Alec_t
    Alec_t
    2,890
    775
    Jul 7, 2015
    What battery will you use?
  6. Robert_fay
    Robert_fay
    124
    34
    Jun 15, 2017
    I think I would need more information to help find a switch. How do you want to mount this switch. When you say 3mm is that a 3x3x3mm max overall size? What are you powering/controlling?
  7. Jbatts39
    Jbatts39
    4
    Jul 24, 2017
    I'm using a button cell. It's powering 1 led. I will carve out a spot on the side of rhe ring and glue it in place.
  8. Alec_t
    Alec_t
    2,890
    775
    Jul 7, 2015
    Don't forget a current-limiting series resistor.
  9. Jbatts39
    Jbatts39
    4
    Jul 24, 2017
    I hopefully won't need one. Planning to match up the battery and led voltage.
  10. Electric-T
    Electric-T
    212
    9
    Jun 4, 2017
    I think most leds can handle 3v just fine anyways. Provided the button cell you are using is a 3v cell
  11. Bluejets
    Bluejets
    4,220
    894
    Oct 5, 2014
    I think you will find the practice of running an led off a coil cell without a resistor is more to do with the cell internal resistance and ability to only provide the small current. Installation of the coil cell on a ring will be rather ratty though even with a miniature switch.
