Help: Desperate for NEC 5.5" LCD display units.
Discussion in 'Electronic Repair' started by Pete, Aug 20, 2003.
  1. Pete
    Pete Guest
    Type NL3224AC35-01
    I urgently require 2 of these as replacement units:
    http://www.nec-lcd.com/english/products/industries/nl3224ac35-01.html
    for repairs to a couple of top end display units in test equipment. Commonly
    used in automotive GPS map-display units, these 320x240 LCDs are PAL/NTSC
    compatible.
    Both failed modules have non lost most of their back lighting and ageing of
    the internal diffusing material has resulted yellowing and a cracking effect
    which has reduced the equipments' useability.
    I have attempted to source these from NEC and their agents but it seems a
    minimum order requires multiples in the 1000s!
    Any help certainly appreciated.
    Pete
