Help designing a latching electronic switch
Discussion in 'Electronic Basics' started by Mark Ashley, May 25, 2005.
  1. Mark Ashley
    Mark Ashley Guest
    Hi there
    I am a novice at electronics so please bear with me!
    I need to design a latching electronic switch with a momentary push switch
    as a trigger. When the trigger is pushed, the switch will latch closed. When
    the trigger is pushed again the switch will toggle back to the open
    position. The switch needs to be able to break/supply power a 12v relay. If
    the circuit loses and regains power the switch should default back to the
    open position.
    For reasons I won't go in to at this stage it is not possible just to use a
    latching switch to supply the power to the relay.
    Hopefully someone can help me if this design is possible!
    Mark
  2. John Fields
    John Fields Guest
    If you can use a single-pole double-throw momentary switch, then
    debouncing is easy and the circuit can be put together with a 4013, a
    transistor and a handful of passive components. If you have to use a
    SPST switch, then it'll have to be debounced differently. Which way
    do you want to go?
  3. Chris
    Chris Guest
    Hi, Mark. Novice and newbie questions always welcome here.
    If you've got half of a CMOS inverter IC (4000-series would include
    4049, 4069, 40106, 74C-series include 74C04, 74C14, &c) or three gates
    you can set up as inverters (NAND, NOR, &c), this circuit might fill
    the bill (view in fixed font or Notepad):
    ~ Logic Toggle Pushbutton With Power-On Reset
    ~ VCC VCC
    ~ 1N4002| |
    ~ VCC - C|
    ~ + ___ ^ C| RY1
    ~ | .----------|___|--------. | C|
    ~.33uF | | 22K | | |
    ~ --- | | '---o
    ~ --- 1N4002| | |
    ~ | |\ | |\ |\ | ___ |/
    ~ o--| >O--|<--o-----| >O---o----| >O--o--|___|-o-| Q1
    ~ | |/ | |/ | |/ 22K | |>
    ~ 10K | | | 220K| | | | |
    ~ | | | | | 22K| | |
    ~ '-' | T '-' '-' |
    ~ | '--o o-------o----||----. === ===
    ~ === || | GND GND
    ~ GND SW1 .022uF |
    GND
    created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
    Make sure you use a darlington NPN transistor (like the TIP120) to
    switch the relay. This keeps the load on the last inverter down to
    around 1mA or so, which any CMOS inverter can handle at 12V. This
    should be good for any relay coil that draws less than half an amp.
    The first inverter with the diode is set up as MML (Mickey Mouse
    Logic). It's only active at turn-on, and forces the input of the
    second inverter to be low right after turn-on. That means the third
    inverter will be low, and your transistor will be off. After a period
    set by the R and C (something on the order of 3ms) the output of the
    first inverter will be high, and the diode will effectively remove it
    from the circuit.
    This stuff was borrowed piecemeal from Don Lancaster's CMOS Cookbook,
    which is a good intro to digital electronics for newbies. It's
    available at Amazon, libraries, and Mr. Lancaster's website:
    http://www.tinaja.com/
    Good luck
    Chris
  4. Mark Ashley
    Mark Ashley Guest
    Hi John
    I can't use SPDT switches easily as the switches are specific (arcade
    machine buttons to be precise). The only way I could make them SPDT would be
    to attach a relay to each one, but wouldn't that increase the risk of
    bouncing?
    Perhaps if I explain exactly what I want to do it will be a little clearer.
    I have built an arcade machine with 8 momentary SPST switches. These, as
    well as a joystick, connect to an xbox pad so I can use it to play xbox
    games. Currently I have a SPST toggle switch which energises a 4 pole relay.
    When energised this physically disconnects the arcade controls and connects
    a normal xbox pad. I want to remove the toggle switch and replace it with a
    circuit which will toggle between the arcade controls and the xbox pad only
    when I press all of the buttons on the arcade controls at the same time.
    Mark
  5. Mark Ashley
    Mark Ashley Guest
    Thanks for this Chris. I will have a look for some information on the IC you
    have used in this circuit so I can find which pins I need to connect to.
    Unless you fancy saving me some legwork... ;)
    Mark
    ~ VCC VCC
    ~ 1N4002| |
    ~ VCC - C|
    ~ + ___ ^ C| RY1
    ~ --- | | '---o
    ~ --- 1N4002| | |
    ~ '-' | T '-' '-' |
    ~ === || | GND GND
    ~ GND SW1 .022uF |
    GND
    from the circuit.
    Good luck
    Chris
  6. John Fields
    John Fields Guest
    OK, that can be easily enough accomplished, depending on what you've
    got the eight momentary switches hooked to. Hopefully, you're
    switching either Vcc or ground on _all_ of them and we can use
    something like an 8-input AND or NAND to decode the all-buttons-down
    state and toggle the latch. Can you post a schematic of what you've
    got or describe the circuit in a little more detail?
  7. Mark Ashley
    Mark Ashley Guest
    One of the legs of each momentary switch is connected to a common ground,
    which comes from a single point on the xbox pad, then daisy chains to each
    switch. This includes the four switches for the joystick I think. The other
    side of each switch then goes to its own point on the pad. I haven't
    measured what is going across the switch when it is closed, but I can do
    this if necessary.
    Is that enough information? I can post more or a schematic if you need me
    to.
    I really appreciate all your help!
    Mark
  8. Mark Ashley
    Mark Ashley Guest
    this if necessary.
    to.
    Mark
  9. Guest
    John - how does this look? (open in Andy's ASCII-Circuit or notepad).
    Would this layout affect the normal functioning of the switches?
    GND 1 2 3 4 5 6 7 8
    | _/ | | | | | | | |
    |-o/ o-o-)-)-)-)-)-)-)------o
    | _/ | | | | | | | |
    o-o/ o---o-)-)-)-)-)-)--\ | __
    | | | | | | | \ o-| \ __
    | _/ | | | | | | \ | )--| \ __
    o-o/ o-----o-)-)-)-)-)-\ \o-|__/ | )--| \ __
    | | | | | | \-----------|__/ | )--| \
    | _/ | | | | | /---------------|__/ | )-o
    o-o/ o-------o-)-)-)-)-----/ o--------------------|__/ |
    | _/ | | | | | o-----------------------o
    o-o/ o---------o-)-)-)--------o | __
    | | | | o-| \ __
    | _/ | | | | )--| \ __
    o-o/ o-----------o-)-)-----------o-|__/ | )--| \
    | | | o-|__/ | )----
    | _/ | | | o-|__/
    o-o/ o-------------o-)------------------o |
    | _/ | |
    o-o/ o---------------o-------------------------o
    (created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
  10. Those gates in Chris's circuit could be in a variety of ICs, and so
    the pins will vary accordingly. For example, here's the circuit
    redrawn for a CMOS 4011 Quad NAND:
    http://www.terrypin.dial.pipex.com/Images/LatchingSwitch.gif
    Note that the circuit uses only 3 of the 4 ('Quad') gates. The two
    input pins of the unused gate are therefore shown wired to ground.
  11. John Fields
    John Fields Guest
    That would be a good idea. I think the switches are wired like this:
    Vcc>--+----- - - ----+
    [R] [R]
    | O | | O |
    | O | | O |
    GND>--+--|-- - - ----+ |
    OUT1 OUT8
    so that each output would be at Vcc until a switch was pressed, and
    then it would go to ground for as long as the switch was pressed. If
    you could verify that by measuring the output voltages with the
    switches open and pressed that would be fine. Also, if you could
    determine the values of the resistors and post that information that
    would be helpful.
    A schematic would be ideal.
  12. John Fields
    John Fields Guest
    Probably not, but you've left the input bubble off of the last gate in
    the top group, plus the implementatuion would take a NOR, an AND and a
    NAND. What I had in mind was more like this:
    Vcc
    [R1] [R2] [R3] [R4] [R5] [R6] [R7] [R8]
    S1___ | | | | | | | |
    +--O O--+----|----|----|----|----|----|----|--A
    |S2___ | | | | | | | | OR Y--A
    +--O O-------+----|----|----|----|----|----|--B OR Y--A ___
    |S3___ | | | | | | | | B OR Y-->OUT TO
    +--O O------------+----|----|----|----|----|--A | B TOGGLE
    |S4___ | | | | | | | | OR Y--+ |
    +--O O-----------------+----|----|----|----|--B |
    |S5___ | | | | | | | | |
    +--O O----------------------+----|----|----|--A |
    |S6___ | | | | | | | | OR Y--A |
    +--O O---------------------------+----|----|--B OR Y--+
    |S7___ | | | | | | | | B SPARE
    +--O O--------------------------------+----|--A | +--A
    |S8___ | | | | | | | | OR Y--+ | OR Y
    +--O O-------------------------------------+--B +--B
    GND OUT1 OUT2 OUT3 OUT4 OUT5 OUT6 OUT7 OUT8 GND
    which uses two quad 2 input NORs; HC32's or CD4071's.
    It could also be implemented with a single chip, a dual 4 input OR
    (CD4072) and a couple of diodes, like this:
    FROM S1>---A
    FROM S2>---B ___
    Y---[CR1>]--+--->OUT
    FROM S3>---C |
    FROM S4>---D |
    FROM S5>---A |
    FROM S6>---B |
    Y---[CR2>]--+
    FROM S7>---C |
    [10K]
    FROM S8>---D |
    GND
    It might even be possible to do it with all diodes and resistors,
    depending on what Mark's circuit looks like.
  13. John Fields
    John Fields Guest
    Unless... Are those all supposed to be ORs and the "o"'s are
    connections? If so, then your approach and mine are basically the
    same.
  14. And I meant to add that the 4011's supply and ground pins (not usually
    shown explicitly on schematics) are 14 and 7 respectively.
  15. Mark Ashley
    Mark Ashley Guest
    Hi John
    Just to clear up any confusion - is me, posting from
    google :)
    No the gates in my circuit diagram are supposed to be AND gates, and the Os
    were connections. I have downloaded a trial copy of CircuitMaker and tested
    your circuit design (the one with the NOR gates) and have had limited
    success. Would you mind if I email you screenshots of the circuit so I can
    more easily explain?
    Mark
  16. Guest
  17. Chris
    Chris Guest
    Hi, Mark. Try this (view in fixed font or Notepad):
    ` (X = X-Box pullup resistor)
    ` T
    ` .---o o---X---------.
    ` | T |
    ` o---o o---X--------.| VCC
    ` | || 4078 +
    ` | T || 8-input |
    ` | --- |'-o| OR(Pin 1)/ .-. VCC VCC
    ` o---o o---X-------.| | NOR(Pin 13) | | + +
    ` | |'--o| | | | |
    ` | T | | 220K'-' .--o---o--.
    ` | --- '---o|__ | | |
    ` o---o o---X------. -|>=| 1 | | |
    ` | '----o|1 |------------|----o |
    ` | T -|__| | | o---->A
    ` | --- .----o| | | 555 |
    ` o---o o---X------' | o--o-o |
    ` | .---o| +| | | |
    ` | T | | 10uF --- '-o |
    ` | --- |.--o| --- | |
    ` o---o o---X-------'| | | '--o---o--'
    ` | |.-o| | | |
    ` | T || === === ===
    ` | --- || GND GND GND
    ` o---o o---X--------'|
    ` | T |
    ` o---o o---X---------'
    ` GND
    ` VCC VCC
    ` .-----------------------. - C|
    ` | | ^ C|
    ` | | | C|
    ` | | === | '---o
    ` | .-----o------.GND | |
    ` | | S | | ___ |/
    ` '----oD Q o--------|___|- -| TIP120
    ` | | | 10K | |>
    ` | 1/2 4013 | | .-. |
    ` A>---------o CLK | | 10K| | |
    ` VCC | | | '-' |
    ` .-. | Q'o-----' === ===
    ` 10K | | | | GND GND
    ` | | | R |
    ` '-' '-----o------'
    ` o-----------'
    ` .1uF ---
    ` GND
    GND when they are pressed, and show a logic level high when they're not
    pressed. First, you need to get a power supply voltage which is the
    same voltage as the power supply of the logic circuit you're
    interfacing (+/- 0.2V). Once you've done that, get a 4078 (8-input
    OR/NOR), a 555, and a 4013 to do your job, along with the handful of
    components shown.
    Not so elegant, but it should do the job. The CD4078 has 8 inputs and
    two outputs -- OR (pin 1) and NOR (pin 13). The OR will only go low
    when all 8 inputs are low (what you want). That signal then triggers a
    555, which is on for about 2 seconds (giving you your debounce) and
    clocking a 4013 set up as a toggle F-F. The R/C at the reset input
    ensures that the circuit will power up with the transistor off.
    You should be able to put all this on a small perfboard, and you'll be
    good to go with the Pretendo relay switch.
    Good luck
    Chris
  18. Chris
    Chris Guest
    The drawing wasn't too clear on something -- It's important that the
    CMOS IC be at the same voltage as the X-Box. That will probably mean
    using a 7805 if the X-box has a 5V supply, and an LM317 if it's an
    oddball voltage. You can use either of these as a post-regulator after
    your +12V for the relay.
    .-------------------> To Relay
    | ____
    12V | | |
    o--o---|7805|---o------> To Logic
    +| |____| |+
    10uF --- | ---10uF
    GND GND GND
    Either that or jsut decide to get a 4PDT telecom relay with a 5V coil
    voltage.
    If you can, find out the power supply voltage and get back to us. You
    might get some more help or another, better idea.
    Good luck
    Chris
  19. John Fields
    John Fields Guest
    I used ORs, since for the circuit to work properly the gates must be
    ORs since what's being detected is the all-zeroes state. If you use
    ANDs, then any switch pressed will cause the output to go low, which
    will effect the toggle.
    It would be better if you posted them to
    alt.binaries.schematics.electronic. That way, everyone who's
    following the thread can stay connected.
  20. Mark Ashley
    Mark Ashley Guest
    I don't understand that. I thought an OR gate would output when *any* of the
    inputs were true. I have copied and pasted this truth table for an OR gate:
    Input A Input B Output Q
    0 0 0
    0 1 1
    1 0 1
    1 1 1
    Also, I though an AND gate would only output if *all* of the inputs were
    true, as below:
    0 0 0
    0 1 0
    1 0 0
    1 1 1
    I am sure that you are correct in what you say, but I would like to
    understand it better rather than just taking your word for it :)
    I have posted them there, under the same heading as this thread.
    Thanks again
    Mark
