Hello everyone,
Quite new here, this being my first post. If you care for an introduction, here is a really short one (if not, skip to the next paragraph ): currently a second year neuroscience student in Canada; found out not too long ago that I like tinkering and making random stuff, but am not very good at it. Started out small with arduino tutorials, and currently looking at a (slightly) more ambitious project.
Anyways! Any help is appreciated for the following:
- I am currently looking to design a custom PCB onto which I will be mounting the fancy WS2812 LEDs. In doing some research though, I am confused as to what components I should include on top of the barebones WS2811 driver + LED package.
- Schematics for an Adafruit design show use of capacitors and resistors (example: https://github.com/adafruit/Adafruit_Breadboard_NeoPixel_PCB), whereas SparkFun show use of only a single 0.1microF capacitor (https://dlnmh9ip6v2uc.cloudfront.net/datasheets/BreakoutBoards/ws2811-Breakout.pdf)
So when I'm designing my own PCB, what are the pros and cons of including/excluding these extra capacitors and resistors?
Thanks!
(If anyone feels like answering the following, that'd be great as well, but these are less urgent matters:
- Assuming I wanted to move away from using a ready made Arduino board, and create my own (likely will be based on the ATMega 328), what are the essential components other than the microcontroller that I should include just to drive the above LEDs? Unessential components include things like indicator LEDs, pin jacks, etc. This board would be integrated in a project with the LEDs and wouldn't need to be as versatile as the Arduino is.
Thanks!
