Help connecting ebike charger to USB
forwhere
Jun 13, 2015
4
Jun 13, 2015
4
I want to connect a USB cord to the battery of my ebike charger. The connector of the ebike in the pictures looks like a male coaxial power connector, but I'm not too sure as it doesn't have the grooves of a coaxial. I'm new to this and have searched all over looking for a connector to connect to USB.
The dimensions are: head (3mm), inner width (8mm).
Would appreciate any pointers in the right direction!
Kay
Harald Kapp
13,700
13,700
What voltage does the ebike charger output? I very much doubt it is 5V. An adapter to USB is useless in that case.
forwhere
Jun 13, 2015
4
Jun 13, 2015
4
Hi Harald - thanks for your reply. It's a 42V output for the charger. How would you set up an ebike battery to charge a phone then? I go on long rides and I'm trying to see whether I can do that. Thanks
Harald Kapp
13,700
13,700
You will need a voltage regulator that creates 5V from 42V. As this is a rather high voltage difference, a switch-mode regulator is the best option to save energy.
You can buy off-the-shelf ebike USB chargers (here's an example) that then should come with a fitting socket.
forwhere
Jun 13, 2015
4
Jun 13, 2015
4
Harald - can we chat on Skype directly? I need more help with this project.
