So I'm working on a project and I have only a little background in electronics. Here is the main idea:
I'm especially stuck on how to make the device be able to accept different kinds of AA batteries, would I simply use resistors attached to an adjustable switch.
Thanks for helping out a noob, I hope I explained everything well.
- Two AA batteries are wired in such a way that the output is approximately 1.4v and 16amps.
- A variable resistor allows the output to be adjusted from nearly 0 to around the above output.
- Something allows the device to be adjusted to accommodate different kinds of AA batteries (1.2v v.s.1.5v v.s. 3v)
- This is all fairly small and will not produce too much heat.
