HellasTechn
- Apr 14, 2013
- 1,579
- Joined
- Apr 14, 2013
- Messages
- 1,579
Good day to all.
I need to build a 220v to 4v 3A psu.
Okay here is the story. On the ship that i work we have a submersible searchlight for when we dive at night. this light uses an 220v incandescent lamp. it is watertight but we have accidently broken the glass. We can not replace the light and we can not have an other one made. So we decided to replace it with a plastic one. Now we can no longer use the incandescent lamp because the heat that produces will destroy the plastic. On the other hand we could use a LED lamp but the led lapms i have found do not produce strong light So i thought maybe use a LED like this one http://www.cree.com/LED-Components-and-Modules/Products/XLamp/Discrete-Directional/XLamp-XML
it is a cree XML-T6. The problem is that it runs on 4.2 volts and upto 3Amps.
Do you think it would be possible for me to build such a psu at a size no bigger than a E14 lamp ?
Or anyone could suggest something better ?
Thank you all !
Thank you all !
