HELLO WORLD - LED BLINKING - HELP
Discussion in 'Microcontrollers, Programming and IoT' started by sheffladreece, Feb 23, 2015.
  1. sheffladreece
    sheffladreece
    22
    Jan 24, 2014
    Newbie here learning how to program.
    Quick brief of equipment-
    Using a USBtinyISP with a ATMega328p MCU on windows 8.1 using programmers notepad in C/C++
    Cant seem to get the LED to turn on at all nethermind blinking.
    Any help woud be appreciated thanks.
    See image of setup and coding as attached
  2. sheffladreece
    sheffladreece
    22
    Jan 24, 2014
    The LED wont even light with the simplest of code, but no problem with make all or programming?????
    #include <avr/io.h>
    int main(void)
    DDRB = 0b00000001; //Data Direction Register setting pin0 to output and the remaining pins as input
    PORTB = 0b00000001; //Set pin0 to 5 volts
  3. sheffladreece
    sheffladreece
    22
    Jan 24, 2014
    [FIXED] I didnt connect the MCU GND to the GND on my board
