Hello, can somebody help wich transistor is like bfg520
Discussion in 'Radio and Wireless' started by michael1978, Jul 27, 2018.
  1. michael1978
    michael1978
    388
    Mar 17, 2012
    Halo,
    i am working on oscillator in multisim, but in database in multisim they dont have this transistor
    can somebody help to find equivalen transistor please.... for multisim thanks
  2. (*steve*)
    25,258
    2,705
    Is this oscillator working up to the GHz range? The ft (Transition Frequency) of this transistor is 9GHz.
    if an ft of 6GHz is OK, then you could try this. The package is different so you'll have to do a bit of redesign of the board. There are others at Digikey. Other suppliers may have different stocked parts.
  3. michael1978
    michael1978
    388
    Mar 17, 2012
    I dont find in multisim, and also is for 88MHZ-108MHZ, I found in internet local oscillator
  4. michael1978
    michael1978
    388
    Mar 17, 2012
    is for frequency 88MHZ -108MHZ
  5. BobK
    7,662
    1,676
    For 100MHz you could try a BF199, which is a common one.
  6. kellys_eye
    kellys_eye
    4,281
    1,145
    Jun 25, 2010
    Isn't that one obsolete now?
    Either way, if you use some supplier websites and their parametric search function, some sites even have multisim files for the devices (iirc).
  7. michael1978
    michael1978
    388
    Mar 17, 2012
    Hello, i dont find in multisim bf199, something else maybe?
  8. michael1978
    michael1978
    388
    Mar 17, 2012
    Sorry but i realy dont know, i am searching on internet to find equivalent transistor bfg220, but i dont find nothing because first i search on internet, after i come here to ask for help
  9. BobK
    7,662
    1,676
    Well, why don't you tell us what RF transistors are available in multisym, then?
  10. michael1978
    michael1978
    388
    Mar 17, 2012
    There are a lot,
  11. michael1978
    michael1978
    388
    Mar 17, 2012
    YOU HAVE A LIST MASTERDATABASE
  12. michael1978
    michael1978
    388
    Mar 17, 2012
    whait BFG235, BFG19S? BFG196, BGF193, BFG135A? but to the list of npn or pnp they are a lotttt
  13. BobK
    7,662
    1,676
    Well, look at the specs of the BFG520 then at the BFG transistors you have access to. Pick one that is close.
  14. michael1978
    michael1978
    388
    Mar 17, 2012
    Is possible to put the schematic, because it was not so good picture in document maybe i make mistake….
  15. michael1978
    michael1978
    388
    Mar 17, 2012
    i pick up BFG235, but is not working
  16. michael1978
    michael1978
    388
    Mar 17, 2012
    is possible that i make mistake because the picture was not so good in document
  17. WHONOES
    WHONOES
    746
    161
    May 20, 2017
    If your Multisim uses the spice platform, Try the model below.
    You should be able to copy and paste into you program!
    From: C:\Program Files (x86)\SIMetrix-SIMPLIS Elements_810\support\Models\bipolar.lb, line 143
    *From Philips SC04 "Small signal transistors 1991" and NS Discrete 1978
    * Base resistance not modelled - no info. CBE estimated. Vce(sat) estimated.
    .model BF199 npn ( IS=1.61E-15 VAF=35.8 BF=150 IKF=0.0467 NE=1.3552
    + ISE=1.494E-14 IKR=0.001 ISC=1.00E-14 NC=1.5 NR=1 BR=5 RC=10 CJC=5.00E-13
    + FC=0.5 MJC=0.2 VJC=0.8 CJE=5.00E-12 MJE=0.4 VJE=0.6 TF=1.86E-10
    + ITF=0.045 VTF=3 XTF=50 RE=1)
    michael1978 likes this.
  18. michael1978
    michael1978
    388
    Mar 17, 2012
    This is the close one BFG234
  19. michael1978
    michael1978
    388
    Mar 17, 2012
    Thnx for help but i use LTSPICE and multisim
  20. WHONOES
    WHONOES
    746
    161
    May 20, 2017
    LTSPICE uses a version of Spice so will probably work.
    I use Simetrix Elements which is the best simulator I have ever come across. The BF199 is in my model data base. Simetrix Elements is free to down load but has a limitation on the number of nodes. That has only ever been a limiting factor on very large sim's that I have tried.
