Heating Element?
Discussion in 'General Electronics Discussion' started by i102bspeedy, Oct 9, 2012.
  1. i102bspeedy
    i102bspeedy
    Oct 9, 2012
    Hi EP Community,
    I would appreciate some help on a project that I am working on.
    My current setup is two AA batteries running in series. These batteries are connected to two copper wires. At the end of the copper wires I have stainless steel wire mesh (.006' strands).
    The problem is that the copper/steel wire mesh gets too hot. One AA Battery is not hot enough.
    Is it possible to use a potetiometer to slightly reduce the power going to the wire mesh? If so, what kind or how would I calculate it?
    (Duracell Rechargeable 1700 mAh batteries)
    Thanks in advance for help.
  2. CDRIVE
    4,960
    652
    May 8, 2012
    I think you would be far better off using (PWM) Pulse Width Modulation..
    Chris
  3. donkey
    donkey
    1,300
    56
    Feb 26, 2011
    I agree. a pot is just a resistor as is your heating element in reality. so rather than having heat from your element it will come through the pot making it hot to touch.
    pwm will adjust the current by sending it in pulses. by sending it in pulses you can go from 100% current down to 1% (even more if you wish). this will allow you to limit temperature. there are devices for drills and motors that use pwm to control their speed, a little luck and you will find one for your heating element. if you want to get real fancy put a temperature sensor and micro controller on it and have it cut out completely when it reaches your ideal temp
  4. BobK
    7,682
    1,688
    You both realize that what he is trying to do is vaporize the THC in some weed, right? My last response on this thread was deleted and this one probably will be as well.
  5. CDRIVE
    4,960
    652
    May 8, 2012
    Maybe Donkey. As for me? Nope not a clue! Should I have?
    Chris
  6. donkey
    donkey
    1,300
    56
    Feb 26, 2011
    I see no mention of the illicit use of this.
  7. davenn
    davenn Moderator
    13,948
    1,990
    There's no deletions showing up in this thread Bob.
    any deletions would show up for any moderator viewing a thread, regardless of which one did the deletion :)
    cheers
  8. BobK
    7,682
    1,688
    Hi davenn,
    It is possible I never managed to make my post. Since I thought I had, and I had mentioned vaporizer, I thought it might have been deleted based on that word. We will see if this one also gets deleted.
    Well, I guess not.
    The reason I think this is what the OP is after, is becuase there was another thread on this a while back and I did some research. People do use batteries and a wire mesh exactly that purpose. You place a little weed in it, heat it to just the right temp and breath in the vaporized THC without the undesired smoke.
  9. (*steve*)
    25,501
    2,841
    No magic like that Bob. The worst that can happen is this:
    **** **** ****ety ****
  10. CDRIVE
    4,960
    652
    May 8, 2012
    Talk about slow! I stared at this for five minutes. Finally got it!
    Chris
  11. BobK
    7,682
    1,688
    Good to know. I know of other forums where certain keywords will cause a silent deletion.
  12. donkey
    donkey
    1,300
    56
    Feb 26, 2011
    I can see no other purpose for this at this time except what bobk has mentioned, however I must point out a few things.
    even though I am dead against the taking of drugs, there are countries where it is allowed so this could be for a legitimate reason in their country.
    although the MAIN use seems to be for illicit drugs there could be others(would love to know if there is another use)
    and the electronics side of this is what interests me,
    I agree with bob that we shouldn't help with items for drug use but having said that, we cannot 100% guarantee this is for drug use.
  13. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    And in those countries and heck even in most States in the US where 'paraphernalia' is loosely defined under law you can pick up such a device legally over the counter or on the Internet shipped to your door... The question begs what is the intent and purpose of making this device, maybe the OP can enlighten as there are 'legal' uses for such a device and reasons one would like to build their own...
  14. donkey
    donkey
    1,300
    56
    Feb 26, 2011
    hey coca... shh keep this a secret, my last post took bout 15 minutes to write because I couldn't figure out how to spell paraphernalia..... shhhhh
  15. CDRIVE
    4,960
    652
    May 8, 2012
    We have a spell check but I use ISpell for my browser.
    Regarding the herb issue: I'm not my brothers keeper and I regard the entire pot issue to be no different from the US's lame prohibition era. Al Capone and all that followed would never have amounted to more than a common street thugs if it were not for prohibition.
    Chris
  16. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Firefox has a built in spell check, hardly perfect but it does the job most of the time... If not I find a Google search to be the best spell check I have ever used, you can destroy the word and Google will still figure it out probably 90% of the time, destroy it another way and you can get near 100% correction... I can't spell worth a poop, it's something I have always struggled with...
  17. CDRIVE
    4,960
    652
    May 8, 2012
    Google, ain't that the truth. I can punch in a word at dictionary.com and have it return "Not Found". Yet Google, like you said, always seems properly reconstruct a butchered word.
    Chris
