F
Farticus
I need to control two 120VAC/5A heating elements off a 240VAC supply.
Two elements will be plugged into one control box and ideally one
"temperature control" is to be fitted to the box. The elements can be
unplugged so that only one element might be operated at any one time. Cost
as always is a factor (as is with most customers!).
The customer suggested a cooker type infinitely variable simerstat, as this
would be good enough for the type of temp control they require.
The only simerstats available locally are 240V and the manufacturer advises
that they will not function properly on120V. Then there would be the need
for interface relay/contactor to switch the element etc. etc....
My first thought were to use a 240/120 transformer with a thyristor circuit
on the 120V output.
My second thought was to use a thyristor without a transformer, restricting
the the thyristor output to a max of 120V via the thyristor control circuit.
The problem with this is that a short-circuited thyristor would apply 240V
to the elements causing problems. A fuse in circuit yes, however this
equipment is to be used in a rough industrial environment, meaning that the
operators WILL replace expired fuses with fencing wire!
Any ideas, past experiences, circuit suggestions using triacs, back-to-back
SCR's or whatever would be appreciated.
on the 120V output.
